Hello
Guest
it is
September 21, 2026, 04:11:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Enable 2 pins via Mcode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Enable 2 pins via Mcode (Read 22542 times)
Steve Harder
1
on:
September 12, 2022, 09:39:40 PM »
Im new...dont know what to do!!!
Can someone tell me if its possible to enable 2 Pins (at once) on my BoB
via an M code?
What would the Macro
VB script look like?...Activatesignal (output 5,6)?
Mach 3
Legacy Woodworking Mavreick 4 x 8
Logged
TPS
2,627
Re: Enable 2 pins via Mcode
Reply #1 on:
September 14, 2022, 06:33:16 AM »
you can only activate OutPuts one by one:
Code:
[Select]
Activatesignal (Output5)
Activatesignal (Output6)
maybe your motioncontroller is able to handle it different.
Logged
Print
Pages:
1
Go Up
« previous
next »
