Hello
Guest
it is
October 24, 2026, 04:54:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
short lines toolpath from an spline problem in Mach4, what is wrong in setup ?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: short lines toolpath from an spline problem in Mach4, what is wrong in setup ? (Read 14017 times)
KatzYaakov
600
Re: short lines toolpath from an spline problem in Mach4, what is wrong in setup ?
Reply #10 on:
September 05, 2022, 11:30:53 AM »
hi
only test on my laptop ,seem no any problem
ill test on machine later
***the segment are not so extreme short
as i see its about 0.3-0.5 mm its quit normal we use this length a lot without any problem
Logged
michal_masek
6
Reply #11 on:
September 06, 2022, 02:43:19 AM »
Thank you,
i decided the problem is the PC where the Mach4 is running. Uninstall, reinstall, still not working. Have no idea where the problem is.
I took another PC today and the problem is solved ! I'am really happy.
Thank you very much.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
