Mach Discussion > Screen designer tips and tutorials
problem with RunFile() after LoadFile
(1/1)
AutomaticInvest-worker1:
Hello,
I would have a question related to adding VB code to a button on a Mach3 screen
If the code of the button is
LoadFile("C:\Mach3\GCode\code2.tap")
RunFile()
then only the loading will be done, without running the code of the loaded file
But if the code is
Sleep(3000)
RunFile()
the after the file is loaded, it is soon also run, after about 3 seconds
which tells me that it is needed to wait for the loading to finish before it can be run
So, with this in mind I modified the code to
While (IsLoading())
Sleep(100)
Wend
RunFile()
where the while loop runs until loading is complete, but I get the same problem as with the 2 lines of code shown above, that is the same as with
RunFile()
Can somebody explain me how to get the file running after loading ?
-- regards
Navigation
[0] Message Index
Go to full version
