Hello Guest it is September 28, 2026, 02:36:14 AM
Author Topic: Offset error g54 and g55  (Read 22685 times)
« on: August 20, 2022, 08:00:05 AM »
So I have a mach3 and my machine have two spindle At the same time
So the problem I defined that spindle 1 is on offset g54 and spindle 2 is one offset g55
The problem that when I have a job with spindle 1  and spindle 2
It activity the spindle 1 and finish it job then it activate spindle 2  and move the offset g55 and start it job
But the problem is if I press pause when it works with spindle 2 then press play the machine forget it is offset and goes to the location as it in g54 offset not g55
