Hello Guest it is October 04, 2026, 12:10:04 PM
Author Topic: Z axis diving with THC150 height controller device  (Read 22777 times)
« on: June 08, 2022, 08:48:37 AM »
Hey there,
My name is Olivier,
I'm helping a local boilermaker to build his own CNC plasma cutter.
We are using Mach3 R3.043.066 version.
They are really close to make it work correctly (V3 on their way, 2000×3000 mm habitable area).
We are using this device (THC150): https://proma-elektronika.com/product/compact-thc-150/.
When launching the job, the Z axis got a problem: it diving slowly to the iron plate...
On Mach3, when we launch the job we can visulizing the heigh constant, then at the end we observe the Z value decremented at once (eventhough we can see i happens continually while cutting).
Like the Z motor needs to be calibrate or corrected by an offset or something like this.
I may be wrong but I think the problem is between mach3 configuration and/or this device.
Can you help me ?
Is anybody recognize this issue?
Do you have any idea what's happening ?
Please let me now.
Olivier.
Re: Z axis diving with THC150 height controller device
« Reply #1 on: June 13, 2022, 03:48:43 AM »
anybody?  :-[
« Reply #2 on: June 16, 2022, 03:42:59 PM »
last up...
