Hello Guest it is October 20, 2026, 08:34:11 PM
Author Topic: Mach 3 suddenly having problems  (Read 22765 times)
« on: June 04, 2022, 10:45:00 AM »
I've suddenly been having intermittent problems with Mach 3 after 5 years of use for my router.  Jog stops working, auto zeroing Z axis won't move, odd extra stuff on tool path screen.  Closing and re-opening Mach 3 seems to fix it for a while, then same stuff occurs.
My setup - dedicated off-line old Windows XP box, Techno Davinci router, Kress router spindle, oem drivers replaced with Gecko 540.  Very simple programs, very occaionnal use - slotting and profiling banjo fingerboards, cutting and inlaying pearl.
This all started after I forgot to shutdown the computer for a month or so, and then it wouldn't boot up.  Discovered it needed a new CMOS battery.  Worked fine after replacing it, but then I started getting these problems.
I'm wondering if somehow Mach 3 got corrupted when the machine shut down?  Would removing and reloading it solve this?  If so, how can I save all my settings?
« Last Edit: June 04, 2022, 10:50:18 AM by dixedanc »
Re: Mach 3 suddenly having problems
« Reply #1 on: June 05, 2022, 09:21:07 AM »
"This all started after I forgot to shutdown the computer for a month or so, and then it wouldn't boot up.  Discovered it needed a new CMOS battery.  Worked fine after replacing it, but then I started getting these problems. "
Most likely BIOS settings were reset to default which may cause problems with Mach3, e.g.
Is the PC now looking for non-existent floppy drive, using interrupts to try and use serial port, game port, audio, etc.
Disable power saving modes in BIOS, unused ports, etc.
Marsha
