Hello Guest it is October 21, 2026, 07:32:07 PM
Author Topic: multiple depth cuts  (Read 26410 times)
Offline garyn
  •  20 20
multiple depth cuts
« on: June 02, 2022, 09:57:03 AM »
what do I need to do to make the Shapeoko cut multiple depths?  I want to cut 3/4" plywood with 1/4" bit in 2 passes.  I have tried saying the bit will only cut 3/8" at a  time, but the tool path shows cutting the plywood in one pass.  What do I need to change?
« Last Edit: June 02, 2022, 10:00:13 AM by garyn »
Re: multiple depth cuts
« Reply #1 on: June 02, 2022, 10:27:24 AM »
What CAM package are you using?
Offline garyn
  •  20 20
« Reply #2 on: June 02, 2022, 10:33:27 AM »
I am using Carbide Create and Carbide Motion.
« Reply #3 on: June 02, 2022, 10:38:00 AM »
So this is a Mach3 support forum so I doubt people will be familiar with those.  Mach3 is more or less the same as Carbide Motion I think.  Do they not have a similar support forum?
Offline garyn
  •  20 20
« Reply #4 on: June 02, 2022, 10:40:20 AM »
Sorry about that
« Reply #5 on: June 02, 2022, 12:24:24 PM »
Not a problem, just that the expertise probably isn't here.
