Hello Guest it is November 12, 2026, 02:37:51 PM
Author Topic: mach4 and wrap gcode  (Read 8834 times)
« on: April 30, 2022, 11:19:59 AM »
 When i load this attached and any wrapping gcode file , Mach 4 latest, just shows' a line on the display ( 4w screen set ) and not the part ??.
    Ed
Re: mach4 and wrap gcode
« Reply #1 on: May 04, 2022, 12:49:27 PM »
 I guess Mach support doesn't look at the forum any more .
      Ed :-[
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: May 04, 2022, 06:01:50 PM »
My guess would be you need to set the A axis rotation in Config - Control - Tool path
You also have no Y axis start point in the code.
« Last Edit: May 04, 2022, 06:06:10 PM by Graham Waterworth »
« Reply #3 on: May 05, 2022, 10:27:46 AM »
  This is a rotary project , Y is not used . This file cuts fine , it just does not show up correctly on the Mach 4 screen.
     Ed
Offline RSL3577
  •  18 18
  • The New Kid On The Block
« Reply #4 on: May 05, 2022, 02:50:36 PM »
 Be sure to check all the modal states and ensure you are using all GCODE calls that can be found in the appropriate MACH GCODE manual. All of which are found within the DOCS folder in their installation.
If a G code is called and not in the manual... the toolpath won't load
