Hello Guest it is November 26, 2026, 02:09:57 PM
Author Topic: How to set ListControl options  (Read 30324 times)
« on: April 18, 2022, 11:14:43 AM »
With the new ListControl item in the screen design, how do I set the options?
When I add something to the String property it shows up in the dropdown, but I can't seem to figure out what the delimiter is for it to split the string into multiple dropdown options. I have tried using a , and ; with and without quotes around each options.
Offline RSL3577
  •  18 18
  • The New Kid On The Block
Re: How to set ListControl options
« Reply #1 on: April 22, 2022, 07:41:04 AM »
Which Screen are you playing with ?
« Reply #2 on: April 22, 2022, 10:13:41 AM »
I’ve created a screen from the blank template and added a list control component.
Offline RSL3577
  •  18 18
« Reply #3 on: April 22, 2022, 11:04:55 AM »
Try using a straight up and down bar  |        Between | your | options a space may or may not be needed. Hope this does it for ya! Fyi there is no scripting behind this screen unless you have created your own, you have use a default screen and modify from there.
