Hello Guest it is November 13, 2026, 09:44:51 AM
Author Topic: emergency mode active wont reset  (Read 47595 times)
Re: emergency mode active wont reset
« Reply #10 on: April 18, 2022, 01:10:59 PM »
Settings for the vfd.  The rest is working using mach3 and the hand wheel.
« Reply #11 on: April 22, 2022, 05:00:00 PM »
I found out  what vfd I have.  I opened up the machine and found the model number etc on the vfd.  It is a MK100-1S2.2g-DK
I was able to find an owners manual for the setting on the keypad.
I followed the instructions to get the setting changed from control from Mach3 to control from the keypad.  I can then test the spindle.  None of the indicator lights come on in the keypad to show power on etc.  Only the number appear.  I can scroll through the settings but can not change any of them.
I tried the spindle calibrate tab and the graph shows up but but does not start.
 Any thoughts on this?  Should I start a new top and posts for this?
Thanks for the help.  Very frustrating
Garnet
« Reply #12 on: December 06, 2022, 09:25:19 AM »
Hi Garnet.
I also purchased a 6040 usb from Chinacnczone Nov 2022. Having lots of issues with language barrier. Would you mind e-mailing me (gerry.sorensen@yahoo.com) to discuss your progress?
