Hello
Guest
it is
October 24, 2026, 08:54:04 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Upgrade to Mach4 v4612 and ESS 278.1, all axes now clunking/skipping
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Upgrade to Mach4 v4612 and ESS 278.1, all axes now clunking/skipping (Read 14693 times)
KatzYaakov
600
Re: Upgrade to Mach4 v4612 and ESS 278.1, all axes now clunking/skipping
Reply #10 on:
April 21, 2022, 08:40:44 AM »
i wonder about the uses of stepper ,the different price from stepper to close loop stepper its very low ( i think bater use servo) but at least
why not use the close loop ? i see here so many complain on problems i never had ,like loose position
Logged
donhar
10
Reply #11 on:
April 21, 2022, 08:42:43 AM »
I completely agree - but when I bought the machine it came with these steppers in place.
For the A-axis I built, I used a servo and I like it a lot more than the steppers. So over time, if the steppers fail, I will replace with servos.
Logged
KatzYaakov
600
Reply #12 on:
April 21, 2022, 08:49:09 AM »
if you have one axiss servo then it can answer yours question,you can check if you have such error also on A
if not then you get the exactly answer
Logged
Print
Pages:
1
2
Go Up
« previous
next »
