Hello Guest it is October 23, 2026, 03:12:42 PM
Author Topic: Used CNC/unknown software  (Read 44107 times)
Re: Used CNC/unknown software
« Reply #10 on: May 04, 2022, 04:00:41 PM »
Yes, well you need to know which pins on the 25-way connector on the BoB go to where and configure Mach3 accordingly.  Without that it will be hard to make any progress.  Where are you located?
Which "Reset" button won't reset - the one on the Mach3 screen?
Offline TPS
  •  2,627 2,627
« Reply #11 on: May 05, 2022, 01:06:01 AM »
try to start with a simple setup. only e-stop and axis outputs.
in here:
https://www.machsupport.com/wp-content/uploads/2013/02/Mach3Mill_Install_Config.pdf
is a step by step description.
