Third party software and hardware support forums. > PoKeys
Problem with Pokeys 57U
(1/1)
chip5:
Hello
I am trying to migrate from using parallel port to USB.
I have Pokeys57U that is currently wired to a single DM542 drive, just to test the system. Managed to get it working but there is a single issue.
When clicking reset in Mach3, I use keyboard to start jogging and release the key after 1 second. When releasing key, drive locks immediately making a clang sound.
When jogging longer or jogging second time it stops by slowing down normally. When double-clicking reset, drive locking happens again.
What could be the problem?
Thanks for any help!
lecso77:
Hi!
How did you connect the DM542 drive to your PoKeys controller? Which pins do you use? Is the device firmware up to date? (I have seen a change from before.)
directlyused:
--- Quote from: chip5 on March 30, 2022, 03:54:52 PM ---Hello
--- End quote ---
I think this is a problem caused by a system software error.
Navigation
[0] Message Index
Go to full version
