Hello Guest it is September 26, 2026, 06:19:08 AM
Author Topic: edit macro  (Read 10984 times)
edit macro
« on: March 29, 2022, 12:31:50 PM »
Good evening
I use this macro for 3d probing, after probing it saves the file in "C: \ WORKS \ SCANNING \ SCAN.TXT" and overwrites the file, I would like (if possible) to save it for me later (scan1.txt, scan2 .txt, etc) or if you asked me for the file name.
is there anyone who can help me to modify the script, since i am not capable of it?
I thank
macro
' Macro scansione con tastatore 3D
' partenza scansione da Xiniz Yiniz Z0
' altezza max pezzo = Z0
' spostamenti in rapido a Zmax
' scansione da X0 a Xmax
Sub Main ()
   If (GetOEMLED(800)) Then
   Message ("ERRORE : MACCHINA IN EMERGENZA ")
   Speak ("errore macchina in emergenza") 'Avviso Vocale
   Exit Function
   End If
Speak ("  confernare avvio scansione") 'Avviso Vocale
Tasto = MsgBox("AVVIO SCANSIONE " ,1+64, "CONFERMARE")
If Tasto <> 1 Then
    Exit Sub
End If
Dim X As Double
Dim Y As Double
Zmin=GETOEMDRO(1006)
Zmax=GETOEMDRO(1005)
Xmax=GETOEMDRO(1019)
Ymax=GETOEMDRO(1020)
StepZsu=GETOEMDRO(1011)
StepX=GETOEMDRO(1003)
StepY=GETOEMDRO(1004)
AvanzZgiu=GETOEMDRO(1007)
AvanzZsu=GETOEMDRO(1008)
AvanzX=GETOEMDRO(1009)
AvanzY=GETOEMDRO(1010)
intNum=1
Open "C:\LAVORI\SCANSIONE\SCAN.TXT" For Output As intNum ' Open to write file.
Code "G17 G21 G90"
Code "G1 Z" & Zmax & "F" & AvanzZsu
Code "G1 X0 Y0 F" & AvanzX
Code "G1 Z0 F" & AvanzZgiu
Label0:
   Code "G31 Z" & Zmin & "F" & AvanzZgiu   ' Avvia scansione fino a Zmin
   While IsMoving()            ' Aspetto mentre si muove
   Wend
X = GetParam("XDRO")
Y = GetParam("YDRO")
Z = GetParam("ZDRO")
Write #1, X , Y, Z
Label1:
   Code "G91"
   Code "G1 Z" & StepZsu & "F" & AvanzZsu   ' Salita Z dopo contatto tastatore
   Wend
   Code "G90"
   If GetOemLed (825)<>0 Then         ' verifica se tastatore attivo
      GoTo Label1
   End If
Label3:
   Code "G91"
   Code "G1 X" & StepX & "F" & AvanzX
   Wend
   Code "G90"
      Code "G91"
      Code "G1 X-" & StepX & "F" & AvanzX
      Wend
      Wend
      Code "G90"
      'If Zdro < Zmax Then
      If GetVar(2002) < Zmax Then
         GoTo Label3
         Else
            MachMsg("Errore, asse Z max superato","ERRORE",0)
            End
         Else
            GoTo Label3
         End If
      End If
   Else
      'If Xdro < Xmax Then
      If GetVar(2000) < Xmax Then
         GoTo Label0
      End If
      Code "G0 Z" & Zmax
      Wend
      Code "G0 X0"
      Wend
      Code "G91"
      Code "G1 Y" & StepY & "F" & AvanzY
      Wend
      Code "G90"
      'If Ydro > Ymax Then
      If GetVar(2001) > Ymax Then
                    Speak ("  scansione terminata") 'Avviso Vocale
                    MachMsg("SCANZIONE TERMINATA ")
         End
      Else
      GoTo Label0
      End If
      End If
   Close intNum
    End Sub
Offline TPS
  •  2,627 2,627
Re: edit macro
« Reply #1 on: March 30, 2022, 01:09:42 AM »
Code: [Select]
Dim FileName As String
FileName = AskTextQuestion("Please enter file name:")
Open "C:\LAVORI\SCANSIONE\" &FileName &".TXT" For Output As intNum ' Open to write file.
Re: edit macro
« Reply #2 on: March 30, 2022, 01:40:23 AM »
good morning
thanks TPS for the help and speed, I installed the modification and from the first tests I must say that it works well.
thanks again for the help !!!!!
