Hello Guest it is October 21, 2026, 02:28:27 PM
Author Topic: Mach4 newbie with questions  (Read 15348 times)
Re: Mach4 newbie with questions
« Reply #10 on: March 10, 2022, 02:13:03 AM »
you change tool manually or its ATC?
Offline Oli81
  •  25 25
« Reply #11 on: March 10, 2022, 04:25:34 AM »
Have both the big router has manual but using some bits with a given height (ring) so I can use them like atc. The other mill has a ATC BT40.
« Reply #12 on: March 10, 2022, 04:32:11 AM »
why not using the tool table?
Offline Oli81
  •  25 25
« Reply #13 on: March 10, 2022, 04:36:05 AM »
This is exactly what I want, I will work with the tooltable like i did it in Mach3.
So set the 3D probe as Tool 1 which is 0 and all others with offset to this probe.
So I need only a M6 macro who stops, move the axis to a good position for TC and den go ahed.
