Hello Guest it is October 30, 2026, 02:48:31 AM
Author Topic: Error Message  (Read 5936 times)
Offline Mauri
  •  328 328
Error Message
« on: March 01, 2022, 02:46:16 PM »
I am using a HiCON card and am currently having issues.
I get this error message and I am trying to find out the problem.
ERROR: Output Index in use by more than one axis. Check Axis Config.
Can anyone tell me if this Control Configuration "Aux. Positions requires changes to be added (see attached file).
Mauri.
Re: Error Message
« Reply #1 on: March 02, 2022, 05:20:12 AM »
For the error message, this is coming from the HiCON plugin. Check each of the 'Output Index' drop downs in each motor config in the HiCON plugin
For the Aux Position counts/unit in the Mach config, these should be set the same as the motor counts/unit otherwise you get issues with DROs not zeroing correctly
