Hello Guest it is October 22, 2026, 01:55:53 AM
Author Topic: Axis 3 commanded while disabled - VistaCNC P2-S4 CNC Control Pendant  (Read 14650 times)
Re: Axis 3 commanded while disabled - VistaCNC P2-S4 CNC Control Pendant
« Reply #10 on: March 04, 2022, 09:16:26 AM »
Axis 3 is A axis, Axis 4 is B axis. Try enabling all axes and see if it works
Offline bcoop
  •  61 61
« Reply #11 on: March 04, 2022, 11:02:30 AM »
Enabling all axis' allows the pendant to work, (kind of)  the command waits until all axis arrive at home position, so it never completes.
Also Mach4 throughs some errors, saying I need to assign a Motor to Axis 5,
I am using motors 0-5 for X, Y, Z, A  (Y Using M1 and M3)   So I am assigning M6 to Axis 5 and Mach doesn't recognize that as a valid motor for some reason, maybe because ESS only supports 5 ?  as a test, I removed M3 from Y Slave, and assign to Axis 5, the error goes away. but can't run it like that,
So it appears that mcCntlGotoZero(inst = 0) (unknown caller)  executes zero of all Axis X,Y,A,B,C and then the Z regardless if they are enabled or not. So it appears that this command can only be used if all axis are configured and functional.
So I have learned a lot but it doesnt appear i can use this function in the pendant the way the API functions, would be nice if it only executed the moves for Axis; that are enabled.
Bob
