Hello Guest it is October 21, 2026, 10:59:09 PM
Author Topic: mach4 with warprunner THC falls to start arc after first hole is cut  (Read 7438 times)
Using mach4  and sheet cam with warp runner thc.
Machine cuts first hole and then it moves on to the second hole and just stops with , waiting for arc okay.
      I will upload photos or files of all the parameters  in sheet cam and mach4
thanks
Re: mach4 with warprunner THC falls to start arc after first hole is cut
« Reply #1 on: February 01, 2022, 03:58:49 PM »
part made in sheet cam
« Last Edit: February 01, 2022, 04:02:53 PM by Thielmetalfab »
« Reply #2 on: February 01, 2022, 04:00:13 PM »
N0010 (Filename: flange20223.tap)
N0020 (Post processor: TMC3in1 Mach4 v004.scpost)
N0030 (Date: 01/02/2022)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 G64 (Constant Velocity Mode - normally used with Plasma)
N0070 m2020 (HC_Z_MAX_VALUE=2)
N0080 m2020 (HC_Z_MIN_VALUE=-0.2)
N0090 m2020 (TMC3IN1_AD1_DELAY_ENABLED=1)
N0100 m2020 (TMC3IN1_AD1_DELAY_VALUE=0.8)
N0110 m2020 (TMC3IN1_AD2_M62_M63_ENABLED=1)
N0120 m2020 (TMC3IN1_AD3_VELOCITY_ENABLED=1)
N0130 m2020 (TMC3IN1_AD3_VELOCITY_PERCENT=95)
N0140 m2020 (TMC3IN1_AD4_VOLTAGE_ENABLED=1)
N0150 m2020 (TMC3IN1_AD4_VOLTAGE_BUFFER=800)
N0160 m2020 (TMC3IN1_AD4_VOLTAGE_CHANGE_PERCENT=4.01)
N0170 m2020 (TMC3IN1_AD4_VOLTAGE_RESPONSE_PERCENT=0)
N0180 m2020 (TMC3IN1_AD5_VOLTAGE_ABOVE=15.1)
N0190 m2020 (TMC3IN1_AD6_VOLTAGE_BELOW=14.4)
N0200 G4 P0.1
N0210 (Part: Pipe Flange)
N0220 (Operation: Inside Offset, center hole, T1: Plasma 35-45amp, plate streel  0.0591 in kerf)
N0230 m2020 (TMC3IN1_TARGET_TIP_VOLTS=115.1)
N0240 m2020 (TMC3IN1_TARGET_BAND_VOLTS=1.5)
N0250 m2020 (TMC3IN1_LINEAR_RESPONSE_BAND_VOLTS_ABOVE=25.25)
N0260 m2020 (TMC3IN1_LINEAR_RESPONSE_BAND_VOLTS_BELOW=15.2)
N0270 m2020 (ESS_DELAY_AFTER_ARC_OKAY=0.01)
N0280 G4 P0.1
N0290 G00 X3.0623 Y3.5342
N0300 (>>>Probe/Ref<<<)
N0310 G31.0 Z-10  F19.685
N0320 G91 G00 Z0.0000 (Incremental move for switch offset distance comp)
N0330 G90 (Back to absolute move mode)
N0340 G92 Z0.0 (Z work coordinate set to 0.0)
N0350 m2020 (HC_WORK_Z_ZEROED=1)
N0360 G4 P0.1
N0370 G00 Z0.1600
N0380 G4 P0.0011
N0390 M62P3 (>>>Torch ON<<<)
N0400 Z0.1500 (Force a small move in Z to make M62 fire the torch)
N0410 G04 P0.1
N0420 G01 Z0.0600 F9.0
N0430 F150.0
N0440 M63P4 (***THC Inhibited, AD2***)
N0450 G02 X3.0786 I0.0081 J-0.0081 F105.0
N0460 X2.6920 Y2.9234 I-0.2619 J-0.2619
N0470 M62P4 (+++THC Allowed, AD2+++)
N0480 X3.0786 Y3.5342 I0.1247 J0.3488 F150.0
N0490 (Operation: Inside Offset, hole2, T1: Plasma 35-45amp, plate streel  0.0591 in kerf)
N0500 M63P3 (<<<Torch OFF>>>)
N0510 G04 P1
N0520 G00 Z0.8937
N0530 X2.9563 Y4.1781
N0540 Z0.1600
N0550 G4 P0.0011
N0560 M62P3 (>>>Torch ON<<<)
N0570 Z0.1500 (Force a small move in Z to make M62 fire the torch)
N0580 G04 P0.1
N0590 G01 Z0.0600 F9.0
N0600 F150.0
N0610 M63P4 (***THC Inhibited, AD2***)
N0620 G02 X2.9726 I0.0081 J-0.0081 F105.0
N0630 I-0.1559 J-0.1559
N0640 M62P4 (+++THC Allowed, AD2+++)
N0650 (Operation: Inside Offset, hole3, T1: Plasma 35-45amp, plate streel  0.0591 in kerf)
N0660 M63P3 (<<<Torch OFF>>>)
N0670 G04 P1
N0680 G00 Z0.8937
N0690 X2.0113 Y3.0368
N0700 Z0.1600
N0710 G4 P0.0011
N0720 M62P3 (>>>Torch ON<<<)
N0730 Z0.1500 (Force a small move in Z to make M62 fire the torch)
N0740 G04 P0.1
N0750 G01 Z0.0600 F9.0
N0760 F150.0
N0770 M63P4 (***THC Inhibited, AD2***)
N0780 G02 Y3.0531 I0.0081 J0.0081 F105.0
N0790 I0.1559 J-0.1559
N0800 M62P4 (+++THC Allowed, AD2+++)
N0810 (Operation: Inside Offset, hole4, T1: Plasma 35-45amp, plate streel  0.0591 in kerf)
N0820 M63P3 (<<<Torch OFF>>>)
N0830 G04 P1
N0840 G00 Z0.8937
N0850 X3.6058
N0860 Z0.1600
N0870 G4 P0.0011
N0880 M62P3 (>>>Torch ON<<<)
N0890 Z0.1500 (Force a small move in Z to make M62 fire the torch)
N0900 G04 P0.1
N0910 G01 Z0.0600 F9.0
N0920 F150.0
N0930 M63P4 (***THC Inhibited, AD2***)
N0940 G02 X3.6221 I0.0081 J-0.0081 F105.0
N0950 I-0.1559 J-0.1559
N0960 M62P4 (+++THC Allowed, AD2+++)
N0970 (Operation: Outside Offset, outside circle, T1: Plasma 35-45amp, plate streel  0.0591 in kerf)
N0980 M63P3 (<<<Torch OFF>>>)
N0990 G04 P1
N1000 G00 Z0.8937
N1010 X3.7214 Y2.2045
N1020 Z0.1600
N1030 G4 P0.0011
N1040 M62P3 (>>>Torch ON<<<)
N1050 Z0.1500 (Force a small move in Z to make M62 fire the torch)
N1060 G04 P0.1
N1070 G01 Z0.0600 F9.0
N1080 F150.0
N1090 M63P4 (***THC Inhibited, AD2***)
N1100 G02 Y2.3675 I0.0815 J0.0815 F105.0
N1110 G03 X4.0962 Y3.2673 I-0.9048 J0.9048
N1120 M62P4 (+++THC Allowed, AD2+++)
N1130 X3.7214 Y2.3675 I-1.2795 J0.0050 F150.0
N1140 M63P3 (<<<Torch OFF>>>)
N1150 G04 P1
N1160 G00 Z0.8937
N1170 Z0.8976
N1180 G92.1
N1190 M30
« Reply #3 on: February 01, 2022, 04:29:25 PM »
Sheetcam
« Reply #4 on: February 01, 2022, 04:39:49 PM »
Sheetcam pic
