Hello Guest it is October 25, 2026, 03:16:16 AM
Author Topic: Probing Help, angle measurement  (Read 8306 times)
Offline nc42
  •  20 20
« on: January 20, 2022, 10:52:04 AM »
I'm trying to run a angle measurement from the probing page and keep getting the error: "invalid plane selection for coordinate rotation" my loaded Gcode includes a G17 and I have tried inputting a G17 in the MDI but still get the same error. Any ideas out there?
Offline nc42
  •  20 20
Re: Probing Help, angle measurement
« Reply #1 on: January 20, 2022, 12:03:20 PM »
I used the hammer fix, just removed the plane check from the lua script....
« Reply #2 on: February 11, 2022, 02:59:04 PM »
having exactly this problem.  could you give me some info to find the "hammer fix" ?
Offline nc42
  •  20 20
« Reply #3 on: February 11, 2022, 03:36:55 PM »
Under the Operator menu select "Open Script Editor"
Then under "Modules" open mcProbing.lua
Search for "invalid plane selection for coordinate rotation" or part of it and delete each instance of the if then statement that leads to the error.
Check that it actually works because I don't really know what I'm doing and can't be held responsible for this idea if it goes bad... That said it's worked for me
« Reply #4 on: February 11, 2022, 03:41:24 PM »
Haha, perfect timing.  I assumed you meant sledgehammer method :) i did exactly as you say and will test it in a few minutes.
« Reply #5 on: February 11, 2022, 06:24:57 PM »
Hmm.  Not working.  Maybe I did something wrong? (I can't imagine that it is that complicated).
Did I comment it out incorrectly?
Code: [Select]
------------- Get current state -------------
local CurFeed = mc.mcCntlGetPoundVar(inst, mc.SV_FEEDRATE)
local CurZOffset = mc.mcCntlGetPoundVar(inst, mc.SV_ORIGIN_OFFSET_Z)
local CurFeedMode = mc.mcCntlGetPoundVar(inst, mc.SV_MOD_GROUP_1)
local CurAbsMode = mc.mcCntlGetPoundVar(inst, mc.SV_MOD_GROUP_3)
local CurPlane = mc.mcCntlGetPoundVar(inst, mc.SV_MOD_GROUP_2)
local CurXPosition = mc.mcAxisGetPos(inst, mc.X_AXIS)
local CurYPosition = mc.mcAxisGetPos(inst, mc.Y_AXIS)
--if (CurPlane ~= 170) and (RotateCoord == 1) then
-- mc.mcCntlSetLastError(inst, "Probe: Invalid plane selection for coordinate rotation")
-- do return end
--end
------------- Check Probe -------------
rc = Probing.CheckProbe(1, ProbeCode); if not rc then; do return end; end
------------- Check direction -------------
if (CurXPosition > XPos) then
BackOff = -BackOff
OverShoot = -OverShoot
ProbeRad = -ProbeRad
end
