Hello Guest it is November 02, 2026, 01:23:36 PM
Author Topic: lazyturn toolpath generation  (Read 185029 times)
« on: January 14, 2022, 12:01:31 PM »
I have read and reread the manual and cannot find my answer. Lazyturn seems to generate toolpaths from max x to min x. How can I change it so the paths generate from min x to max x?
Re: lazyturn toolpath generation
« Reply #1 on: January 14, 2022, 12:44:55 PM »
Also if I set the tool position to min x lazyturn cannot generate a tool path
« Reply #2 on: February 01, 2022, 10:03:18 AM »
The pathing is intended to cut away the stock until it reaches the contour of the piece. You don't start removing stock from say the profile to the exterior of the piece ....... maybe i am missing something !
« Reply #3 on: February 01, 2022, 10:42:51 AM »
I obviously understand that, it's just that I am trying to generate tool paths from min x not max x
« Reply #4 on: February 01, 2022, 03:07:07 PM »
Maybe I was using an incorrect axis, I am looking at z axis. My part is 46" long and the toolpath insists at starting at 46". I want it to start at 0".
« Reply #5 on: February 02, 2022, 04:09:57 AM »
Post  the DXF file.
Have a look at figure 3.5.1 Page 2  of 6 of Appendix "B" of the manual. You need the dwg origin to be correct before importing.
« Reply #6 on: February 02, 2022, 12:58:36 PM »
I guess the program is designed to work right to left. Is there a way to change tool path generation from absolute to incremental?
« Reply #7 on: February 03, 2022, 05:29:37 PM »
Not that I am aware of for LazyTurn.
