Hello Guest it is October 21, 2026, 03:29:21 PM
Author Topic: Glitch on X movements  (Read 22100 times)
Re: Glitch on X movements
« Reply #20 on: January 21, 2022, 04:21:08 PM »
have attached a couple of pics of my two BoBs.
I will eventually get around to making both these boards anew. The IO board will have a minor modification to do with the PWM output circuit.
The Servo board will have the dual OpAmp's replaced with a dedicated line driver IC (AEIC-7272-S16).
Otherwise the board layout will stay the same, namely two boards 60mm x 180mm.
I am giving some consideration to making one single board which would allow the ESS to sit atop the BOB in a similar manner to the MB3.
