Hello Guest it is October 22, 2026, 09:10:06 PM
Author Topic: Setup Mach4 for floating head switch  (Read 15324 times)
Re: Setup Mach4 for floating head switch
« Reply #10 on: November 02, 2022, 10:05:13 AM »
Hello, I bought you an icon integra card with arc pro for a plasma table, with mach 4.
My table is equipped with an anti-collision support on the P11input1 input which will be used for the PROBE and I would like to be able to use the same input to block the machine in the event of contact outside the PROBE. (during JOG and cut)
I can attach my Mach 4 setup if you want. Thanks in advance Laurent.
