Hello Guest it is October 24, 2026, 09:46:30 PM
Author Topic: PROBLEM WITH LASER START-UP POWER WITH PMW MACH4 AND POKEYS  (Read 19566 times)
Re: PROBLEM WITH LASER START-UP POWER WITH PMW MACH4 AND POKEYS
« Reply #10 on: December 07, 2021, 03:09:35 PM »
But I don't know if I am configuring M62Px correctly.
I associated Spindle on (therefore M3) with relay 1 and spindle forward with relay OC 1.
But how and where is it declared that M3 = spindle on and where is written that M62P1 + = *********X?
Following the tests M62 / M63Px does not work with the gcode (above), M3 activates relay 1 and relay OC but M63P1 does not cut OC.
No need to use spindleOn/spindle ffw for M62P*, just set pokeys oc to an Mach4 output (ex. Output2) and use M62P2/M63P3 with follow code of G0/G1, be sure that u have the latest upgrade of pokeys software/board. There is a plugin from 10/2021 and software vs is 8.85.
« Reply #11 on: December 08, 2021, 08:36:42 AM »
Yes ok I saw for the mach4 output, I will try the config.
On the other hand on pokeys we find that the soft version:
  PoKeys v4.5.0 Configuration and PoBlocks (8.9.2021) .exe (53.41 Mb)
and PoKeys Mach4 plugin version 8.78.0.4342 + manuals.zip (7.5 Mb) with date of 09/2020
I don't see a plugin version of 10/2021.
Otherwise my softwares are ok.
I'm doing tests tonight.
Regards
Thank you
« Reply #12 on: December 08, 2021, 01:25:24 PM »
Hi
I just tried the config.
I have mapped the output 0 on pokeys with the output OC1.
(see picture) and do the gcode with M62P1 but no activation of the OC1 output.
I looked for other solutions, put the output on an Enable or put OC2 (M62P2) but ditto, I have the latest version mach4, pokeys57cnc, plugin mach4 and firmware. I also checked the M62 / M63 option in the plugin
I also saw that there are macro files in the M162 and M163 macros folder, what are they used for?
If you have any suggestions, I'm interested
Thank you
« Reply #13 on: December 08, 2021, 04:44:04 PM »
Hi, first to activate Output0 you need to do M62P0 and follow with movement, like:
M62P0
G1 X10 F300
Don't know, i don't have those macros and every macro is used base the machine use.
I get from polabs support the latest, i don't know if i can share it here or is ok for you. I had problems with M62 too before i upgrade plugin/software, don't spend time figure it out without upgrade the versions. Ask polabs for newer or tell me to send it to you.
« Reply #14 on: December 10, 2021, 03:27:16 AM »
I opened a ticket at polabs but I want the latest versions if you want?
Thanking you, I will do the tests this weekend.
Thank you
« Reply #15 on: December 10, 2021, 07:31:40 AM »
I message you..
