Hello
Guest
it is
October 23, 2026, 07:49:59 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
OEM Buttons
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: OEM Buttons (Read 22115 times)
Kareem
1
OEM Buttons
on:
November 16, 2021, 03:56:56 AM »
Which OEM code is used for enter a target value for x axis directly without G0 before it?
Logged
Authentic Maidens
TPS
2,627
Re: OEM Buttons
Reply #1 on:
November 20, 2021, 02:34:27 AM »
there is no particular OEM code for this.
you have to use a OEMDro to enter the value, for example 1500
and the a button witch uses VBScript to excecute the command
Code:
[Select]
Code "G0X" & GetOEMDro(1500)
Logged
Print
Pages:
1
Go Up
« previous
next »
