Hello Guest it is October 12, 2026, 09:01:00 AM
Author Topic: z axis depth increasing with every cut  (Read 24953 times)
« on: November 05, 2021, 01:09:26 AM »
we are having an issue with the Z axis on our cnc router, when cutting multiple vent holes in 2.5mm aluminium sheet, starts off fine cutting at right depth at 0.5mm pass cuts and cut through, but by time we finish cutting 20 to 30 slots Z axis is cutting sheet all way through on first cut and continuing into the sacrificial board, can anyone advise
  •  9,374 9,374
Re: z axis depth increasing with every cut
« Reply #1 on: November 05, 2021, 01:52:52 AM »
The first thing to check, and this is the most important thing, is that the cutter is truly secure and not moving within the collet during use.
Secondly, as a test, reduce your Velocity and Acceleration settings for your Z Axis in Motor Tuning by 50% (and apply the change). Does the problem still exist ?
« Reply #2 on: November 05, 2021, 01:55:27 AM »
thanks Tweakie, will try this and check how it goes
« Reply #3 on: November 15, 2021, 08:27:37 PM »
tweakie, thanks for the tip, all is working fine now, your help is very much appreciated.
  •  9,374 9,374
« Reply #4 on: November 15, 2021, 11:36:26 PM »
Excellent news  ;)
