Hello Guest it is November 10, 2026, 01:55:50 AM
Author Topic: Round Double and ACos, ASin  (Read 8799 times)
« on: October 30, 2021, 07:57:39 PM »
Hello good day, i generate my code con Gcode:
Code "G1 Z" & z(i) & " Y" & y(i) & " F" & Fm(i)
 but my result are several point decimal, then this exist function as round(z(i),3) for round a three point decimal or as i can make this?
I no find the function Acos and Asin, only Atn or this two function no available?
thanks
Renato
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Round Double and ACos, ASin
« Reply #1 on: October 30, 2021, 08:28:47 PM »
Mach3 uses a Cypress version of VB and has a reduced instruction set so the best you have is the trig commands are :-
Exp, Log, Sqr, Rnd, Abs, Sgn, Atn, Cos, Sin, Tan, Int, Fix
The manual is on the forum if you search for it :-  VBScript_Commands.pdf
« Reply #2 on: November 05, 2021, 09:26:37 AM »
thanks
