Hello Guest it is October 26, 2026, 01:38:20 AM
Author Topic: c axiss move while z axiss comand  (Read 25641 times)
Re: c axiss move while z axiss comand
« Reply #10 on: October 25, 2021, 01:03:58 PM »
do yo have an MPG, noise on an MPG signal effectively causes jog moves.
« Reply #11 on: October 25, 2021, 01:17:18 PM »
I have mpg wireless with the new version there the mpg wireless plugin
But as i told before its not noise
Because i see the movment on mach screen ,its not random movment without mach comand
The movment its something mach give that movment comand
« Reply #12 on: October 25, 2021, 01:32:47 PM »
try disabling the wireless MPG.......does the fault still occur?
« Reply #13 on: October 25, 2021, 01:34:28 PM »
Maybe the plugin do it? Because noise for sure its not
« Reply #14 on: October 25, 2021, 01:41:41 PM »
electrical noise could interfere with the wireless and Mach would interpret the event as an MPG command.....so noise
is still a possibility whether you choose to believe it or not. If you disable the wireless MPG does the fault occur?
« Reply #15 on: October 25, 2021, 01:45:32 PM »
Now its late here (21:45) so im not at work shop
But as i start this chat i had this problem with machine that have yhe plugin but not have the mpg
And on that machine i also have small not comand movment ,and same its movment comand from mach
« Reply #16 on: October 25, 2021, 01:48:44 PM »
https://youtu.be/gtdX7FVaggo
I upload the video please watch
« Reply #17 on: October 25, 2021, 01:52:36 PM »
https://youtu.be/lTUBX1y8ZFw
Here onther sample ( the machine without mpg) axes move while comand onther axes
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #18 on: October 25, 2021, 04:50:30 PM »
Why are you so sure its not noise?
Depending on your hardware the position can be sent back to mach so it could be noise.
« Reply #19 on: October 25, 2021, 04:52:28 PM »
How???
Mach dont have any close loop detection
I wish there where close loop or following errors detection
