Hello Guest it is October 25, 2026, 01:23:30 AM
Author Topic: Tool changing to wrong number  (Read 14264 times)
Offline nc42
  •  20 20
Re: Tool changing to wrong number
« Reply #10 on: September 12, 2021, 12:56:20 PM »
thanks, swapped the ini from my backup and back to working
« Reply #11 on: November 20, 2021, 05:53:52 PM »
You need to replace the parameters.ini file in your profile folder. For some reason this can get corrupted and causing this setting to always revert to next tool to use
Just want to say thanks. I just had this exact same issue happen to me. I found this thread, and tried first to just change the value in the controls panel, but every time I did it just reverted. So I found that my parameters.ini file was corrupt. Just removed that and let mach4 recreate it then all was good.
