Hello
Guest
it is
November 13, 2026, 06:54:37 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 vs Mach3 Gcode?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Mach4 vs Mach3 Gcode? (Read 18155 times)
stevehuck
425
Re: Mach4 vs Mach3 Gcode?
Reply #10 on:
September 01, 2021, 01:54:55 PM »
I did swap the G02 and G03 and all is well. Thank you for taking the time to reply!
Logged
stevehuck
425
Reply #11 on:
September 05, 2021, 03:52:24 PM »
I found that there are more than a few differences so I copied the Mach3-turn PP and renamed the copy Mach4-Turn and made the appropriate changes. I was able to post some code that works like it should. Problem solved!
Logged
Toshio.K
166
Reply #12 on:
September 05, 2021, 11:10:00 PM »
Answer Hello Mr.stevehuck.
It was good to have it.
It is a stone's throw.
My problem is in trouble because I can't solve it.
I'd like to get rid of the Mach4 failure, but I don't know.
Logged
stevehuck
425
Reply #13 on:
September 06, 2021, 10:19:27 AM »
I see you are having trouble with probing. If I had any clue how it worked I would try to offer some help
Logged
Print
Pages:
1
2
Go Up
« previous
next »
