Hello Guest it is November 04, 2026, 06:25:43 PM
Author Topic: Current Position does not change while moving axes - 7766  (Read 18419 times)
« on: August 27, 2021, 02:22:54 PM »
If anyone can help me with this problem, I'd be so grateful....
The Current Position does not update when I move any axis. The Machine Coordinates on the diagnostics screen shows my position, but the Current Position values don't change - (no change with jogging or g-code). I'm homing with limit switches, and that all works fine. Everything else seems to work as normal, but I cannot figure out how to fix this.
I'm running Mach4 Hobby, and a HICON 7766, with steppers (no encoders).
Cheers.
David.
Re: Current Position does not change while moving axes - 7766
« Reply #1 on: August 30, 2021, 11:34:46 AM »
Turns out it was my stupidity that caused the problem. I had Motors 0-2 enabled in the Aux. Positions tab.
