Hello Guest it is November 13, 2026, 11:49:39 PM
Author Topic: Can't save edited screen load script  (Read 16186 times)
Re: Can't save edited screen load script
« Reply #10 on: August 22, 2021, 05:14:58 PM »
I assume I should change mine to match yours?
« Reply #11 on: August 22, 2021, 05:17:57 PM »
Right of "Screen load Script" where says "pageid=0" if you click once with the mouse will get some "..." click there and will open the editor of load script.
There you will make the changes you want
« Last Edit: August 22, 2021, 05:20:50 PM by Greekart »
« Reply #12 on: August 22, 2021, 05:37:12 PM »
That did the trick! Cycle start button is working.
Here is what I ended up with.
[mc.ISIG_INPUT0] = funtion (state)
    if (state == 1) then
        Cyclestart()
    end
end
Thank you for taking the time to help. Much appreciated. Now I have a few other things to fix and I will be able to start making parts!!
« Reply #13 on: August 22, 2021, 05:39:16 PM »
        Cyclestart()
    end
end
No problem, wish you the best!
