Hello Guest it is November 13, 2026, 02:52:21 PM
Author Topic: mach3 goes to Z5 when pressing STOP  (Read 23230 times)
« on: August 21, 2021, 08:32:02 AM »
Hello everyone,
a lot of times I need to set Z0 below the top of material and every time I do that I cannot press STOP if something goes wrong because when I press STOP mach3 goes to Z5... this is fine if you have Z0 on top of the job, but say you have your Z0 20mm below the top of the job... the cutter will crash into the material. Does anyone know if it is possible to change this behaviour? e.g. pressing STOP will NOT lift Z, or will lift Z 5 or whatever mm above current position, not going to absolute Z5?
many thanks to whoever will answer
Re: mach3 goes to Z5 when pressing STOP
« Reply #1 on: August 22, 2021, 12:47:30 AM »
try looking under the Safe-Z setting.
« Reply #2 on: August 22, 2021, 02:11:18 AM »
thank you!
