Hello Guest it is November 12, 2026, 11:07:42 PM
Author Topic: Mach4 wizard function  (Read 11900 times)
« on: August 19, 2021, 09:54:40 AM »
Hi All
I am new here, I am trying  the mach4 function, when I use bolt hole wizard, I only can save and load the file one time if I use a same file name, but the wizard works well if I use different file name each time after I change setting :(, the mach4 is demo version, someone know how to be able to use the same file name? thanks.
Re: Mach4 wizard function
« Reply #1 on: August 19, 2021, 11:56:23 AM »
Hi I find out the problem that I have to close the file first and to use it again. :)
