Hello Guest it is November 22, 2026, 06:21:20 PM
Author Topic: Mach 3?  (Read 28333 times)
Re: Mach 3?
« Reply #10 on: October 18, 2007, 06:45:22 PM »
Where can I get the XML file at?
And what would be an unreasonable rate?
Re: Mach 3?
« Reply #11 on: October 18, 2007, 06:58:44 PM »
Your XML file will be in your C/Mach3 folder. I have no idea what yours will be named. Mine is MyMach.xml for example. Set the rate to 25%.
Re: Mach 3?
« Reply #12 on: October 18, 2007, 07:06:59 PM »
Nope no life. How can I check to make sure that Mach3 recognizes the mill is hooked up?
Re: Mach 3?
« Reply #13 on: October 19, 2007, 02:23:29 AM »
xml looks ok and it jogs here fine by keyboard.
When you jog with the keyboard do the DROs on the screen move?
Have you got the correct post address set on the first page of Ports and Pins? Check this by going to Control Panel > System > Hardware > Device manager> then expand the ports list and double click on your LPT port. On the resources page you should see I/O Range, it is the first 4 letters/digits  that you want to enter for your port address in Mach.
Edit forgot this is vista so maybe the location of device manager will be different
Re: Mach 3?
« Reply #14 on: October 19, 2007, 05:42:11 AM »
The first four letters I see are: 03BC
Nope, DRO's don't change.
Re: Mach 3?
« Reply #15 on: October 19, 2007, 02:58:59 PM »
Well the 03BC is not in the xml  that you attached so you would need to put that as your port address. Onc thing though is that address sounds more like a com port, is it definitely the LPT address?
The other part of your reply is more worrying though as if you Jog via the keyboard you should see the DROs moving whether you have the correct address in or not.
Have you tried redownloading and reinstalling Mach? maybe you had a bad download.
Re: Mach 3?
« Reply #16 on: October 20, 2007, 08:01:32 AM »
I fixed the problem, instead of using my vista laptop, I'm using my XP desktop. Problem solved.
