Hello Guest it is November 22, 2026, 03:40:40 PM
Author Topic: Mach3 origin off on a circle  (Read 23574 times)
« on: July 17, 2021, 07:49:43 AM »
For reference, I'm using Mach3 version R3.043.062.
When I draw a simple circle with the center of the circle at origin at X0, Y0, Z0 and load the G-code to Mach3 on my engraving CNC the center of the circle is no longer at the X0, Y0, Z0 coordinate.   I can run the same code on my Tormach which also uses Mach3 and it works correctly. If I draw a square in the same position, it works with no trouble.
I've been using Mach3 for better than 15 years and never run across this before.  I even removed and reinstalled Mach3.
I thought about trying a different version of Mach but I'm running a SmoothStepper board and it calls for this version.
Here's a copy of the code:
N1 G00 X0. Y0. Z0.1
N2 Y0.75
N3 G01 Z-0.02F5
N4 G03 I0. J-0.75F30
N5 G00 Z0.1
N6 G00 X0 Y0
I've attached a picture of Mach3, note the origin of the circle in the tool path window.
I'm really stumped on this one.
Any ideas?
  •  9,378 9,378
Re: Mach3 origin off on a circle
« Reply #1 on: July 17, 2021, 09:25:41 AM »
What do you have in your Initialization String (Config. page) ?
« Reply #2 on: July 17, 2021, 10:40:48 AM »
Config page?  You lost me...
« Reply #3 on: July 17, 2021, 11:07:46 AM »
Initialization string has G80 in the space.
