Hello Guest it is October 26, 2026, 10:07:32 AM
Author Topic: Can you directly command the controller using SDK?  (Read 25471 times)
« on: June 12, 2021, 10:05:03 PM »
I'm writing here because I'm curious.
I want it to work on the UI screen that I made arbitrarily, not on the Mach3 UI.
I've looked around SDK forum, but there's only Plug-in content.
Can I send commands directly to the controller by code without using Mach3 Program?
If possible, I would appreciate it if you could help me solve this situation in detail.
« Last Edit: June 12, 2021, 10:08:13 PM by hjim »
