Hello Guest it is October 11, 2026, 05:28:31 PM
Author Topic: Mach 4 and Pokeys MPG  (Read 17416 times)
« on: June 06, 2021, 09:39:42 AM »
Having an issue with an MPG connected thru PoKeys.  When the increment is set to 1.0000 or 0.1000 the axis starts to move but then almost immediately returns to its starting point.  Sometimes it even goes back more in the opposite direction I am trying to move it.  The MPG is connected to pins 1 and 2 of the Pokeys as directed in the PO Keys manual.  Has anyone else seen this?
Re: Mach 4 and Pokeys MPG
« Reply #1 on: June 06, 2021, 06:22:51 PM »
Hi rexx42
Can you check your counts per detent is set correctly - most are 4 counts per detent.
Steve
« Reply #2 on: November 16, 2022, 09:29:07 AM »
I have the same problem. How do you solved it?
