Hello Guest it is October 05, 2026, 12:06:54 PM
Author Topic: Axis not working or moving in same direction  (Read 39597 times)
  •  9,374 9,374
Re: Axis not working or moving in same direction
« Reply #10 on: June 08, 2021, 06:27:52 AM »
Locate the output wiring from you breakout board and check that :
Pin 6 is connected to your X axis Driver Direction pin
Pin 2 is connected to your X axis Driver Step pin.
Pin 7 is connected to your Y axis Driver Direction pin
Pin 3 is connected to your Y axis Driver Step pin.
Pin 8 is connected to your Z axis Driver Direction pin.
Pin 4 is connected to your Z axis Driver Step pin.
(this is to test that you have the correct pins specified in Motor Outputs).
Using a multimeter check the output from you Parallel Port will toggle Pin 6 between 5 Volts and 0 Volts when using the Left and Right Arrow keys.
(this is to test that the output from your Parallel Port is to the 5 Volt TTL standard and not to the 3.3 Volt TTL standard).
Offline TPS
  •  2,627 2,627
« Reply #11 on: June 08, 2021, 06:49:30 AM »
here:
https://www.youtube.com/watch?v=uglCm_qsojk&t=329s
is a good tutorial how to test.
« Reply #12 on: June 08, 2021, 02:44:39 PM »
Ok, watched the video again and retested to verify all pins were working. The voltage is 3.4 (not 5) on the pins that indicated voltage and 0 on the others.
  •  9,374 9,374
« Reply #13 on: June 08, 2021, 11:48:36 PM »
Older equipment used the 5 Volt TTL standard and may not operate reliably at the 3.3 Volt TTL standard. This thread explains ; https://www.machsupport.com/forum/index.php?topic=34848.0
You could either fit a 5 Volt PCI Parallel Port card or a new Breakout board which accepts the 3.3 Volt TTL standard inputs and outputs 5 Volt TTL or use an External Motion controller which supports Mach3. There are other options but I think these are probably the easiest to implement.
« Reply #14 on: June 09, 2021, 11:11:18 AM »
I will try to work on it as soon as possible (hope this weekend). If this is the only issue that would be great....Again Thanks
Larry
« Reply #15 on: June 21, 2021, 02:43:58 PM »
I would like to thank both of you for you help...I was able to hookup a UC100 and all axis are moving properly. Will load GCode and test mill a piece this week but confidence is high there will be no issues.
Again thanks for your time and expertise
Larry
