Hello Guest it is November 14, 2026, 08:56:25 PM
Author Topic: Mach3 driver problem  (Read 36548 times)
« on: May 20, 2021, 02:45:35 PM »
I’m so confused so if I install mach3 on my pc (win xp) with the driver part my g code doesn’t loads but is not right in the tool path if I load it without the driver part it loads perfect but then can’t use the cnc 🤯🤯 I’m using a hobby cnc desktop with lpt port please help Iv tried lots of different g codes  :'( :'( :'( :'(
Offline ZASto
  •  434 434
Re: Mach3 driver problem
« Reply #1 on: May 20, 2021, 04:09:49 PM »
Without a license, limit is 500 lines with driver loaded.
Without driver loaded Mach3 works in preview mode without generating movements.
So, no need to cry  8)
My personality is who I am.
« Reply #2 on: May 20, 2021, 04:26:38 PM »
Yes I know that it’s defo not due to the limitations as I have uninstalled it and reinstalled without the driver and loads perfect but then the cnc will not drive
Re load it with the driver and the code not work right but I can get the cnc to move
Offline ZASto
  •  434 434
« Reply #3 on: May 20, 2021, 05:17:57 PM »
So you did not get it.
Without driver and without license Mach3 will load all G-code for preview - no motion of machine.
With driver and without license - 500 line limit
With driver and with license - almost no limit on G-code size
