Hello Guest it is October 21, 2026, 12:20:26 PM
Author Topic: Strange toolpath  (Read 23813 times)
Re: Strange toolpath
« Reply #10 on: October 15, 2007, 10:25:38 AM »
Hi Graham,
thank you for your help.
I have just tested that code and it work well.
If I use the G52 code all subroutines work well and the multiple object are OK.
But if I use the programming with expression ( like [#9001+2.35]) the software work not good.
I prefer to use the expression because the position of objecs are calculated with a numeric procedure ( the code I posted is only a part of a complex program).
Do you know why my code with expression don't work well ?
There is a reason ?
I have also seen that in the preview window the tool path is not correct ..... there are a lot of white lines that are not included in my theorical path of tool.
Do you Know bugs about programming with expression ?
Thanks.
Maurizio
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: October 15, 2007, 10:31:12 AM »
I think it is the fact that you are using #9001 and above, these are normally used by the system and may be getting corrupted. Art gives no guarantee that the # numbers work in all conditions.
You can use the G52 with # numbers
E.g.
#1=100.125
#2=120.000
G52 X#1 Y#2
I would keep away from the 9000+ numbers
Graham.
« Reply #12 on: October 15, 2007, 10:35:35 AM »
Dear Graham,
Thanks for your help and for your time !
Best Regards.
Maurizio
