Hello Guest it is October 10, 2026, 04:37:59 PM
Author Topic: Mach4 rapids Z height prior to x/y movement?  (Read 14458 times)
Re: Mach4 rapids Z height prior to x/y movement?
« Reply #10 on: June 11, 2021, 03:13:02 AM »
Thanks for the thoughts Steve. I have limited experience.
I note that SheetCam has a Post option something along the lines of "Mach4 Plasma no Z" or something like that, as well as the "Mach4 Plasma" option.
Generally, would a plasma post be expected to retract between rapids?
Offline smurph
  •  1,575 1,575
« Reply #11 on: June 11, 2021, 12:27:56 PM »
Yes, if the part being cut has many cuts or obstacles instead of one long single cut.  Basically, the machine SHOULD operate as per the simulation in sheetcam.
Steve
« Reply #12 on: June 11, 2021, 07:48:07 PM »
Thanks again Steve.
I'll head over to SheetCam and see what I can find out there.
Nicholas.
