Hello Guest it is October 12, 2026, 08:37:41 AM
Author Topic: Mach3 Jerky motor motion when Using MDI input  (Read 26843 times)
« on: May 18, 2021, 08:54:22 PM »
HI,
I'm after some help with Mach3 running an XHC controller (ethernet), Fully licensed version
I've been through all the motor tuning and the machine (3 axis router) runs smoothly when running code and or jogging with arrow keys + shift.
I've seen multiple posts on similar issues but not found a solution that works on any.
When i try entering and MDI instruction or try to use go to zero, the motors get jumpy and in most cases lose their position very quickly.
This is very frustrating and confusing as I understand the motor tuning sets the max allowable speed and when jogging at 100% the movement are perfectly smooth.
Re: Mach3 Jerky motor motion when Using MDI input
« Reply #1 on: February 16, 2022, 03:07:31 PM »
Same problem here
« Reply #2 on: November 24, 2022, 12:51:36 PM »
Similar here. Smooth jogging with MPG or keyboard
but start stop movement on all axes with gcode or MDI
all settings look OK CV mode etc.
But all works well with spindle on (even if spindle is powered off or set S0)
Scratching my head all day!
Offline reuelt
  •  520 520
« Reply #3 on: November 24, 2022, 03:31:24 PM »
HI,
G0 speed is probably simply too high.
(Get a WARP9 ESS Motion Control Card instead.)
"the gift of God is eternal life through Jesus Christ our Lord"
