Hello Guest it is November 23, 2026, 01:12:11 AM
Author Topic: Spindle will not start with new versions of Mach4  (Read 6546 times)
Offline Mauri
  •  328 328
« on: April 12, 2021, 11:28:40 PM »
Steve, (smurf)
I am having an issue starting our spindle with the latest mach4 versions.
We purchased a new inverter but the same issue came up.
I use HiCON to run it.
We checked all the electricals on our controller and all is fine.
The 10V is being sent.
But the short is not happening.
We tested an older Mach4 version and it worked just fine (wasted purchase)
So the issues are with the newer version of Mach4 and or the Script changes are not working as they should.
Below is my signal script.
If you require the other script changes please advise.
Mauri.
if SigLib[sig] ~= nil then
    SigLib[sig](state);
end
-- HiCON and Controller Button Signal Script
local inst = mc.mcGetInstance();
if (sig == mc.OSIG_MACHINE_ENABLED) then
    machEnabled = state;
end
-- Enable/Disable
 if (sig == mc.ISIG_INPUT14) and (state == 1)then --mc.ISIG_INPUT4-- on HiCON Used as an enable button
       wx.wxMilliSleep(10)
        local inst= mc.mcGetInstance();
        local reg = mc.mcSignalGetHandle(inst, mc.OSIG_MACHINE_ENABLED)
        state = mc.mcSignalGetState(reg);
            if(state == 1)then
                state = 0
                hsig, rc = mc.mcSignalGetHandle(inst, mc.OSIG_ENABLE3);
                mc.mcSignalSetState(hsig, 0); --sets Enable_3 to False- Turn off if on
            else
                state = 1
                hsig, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OPT_STOP);
            mc.mcSignalSetState(hsig, 0); --sets Opt Stop_1 to False
            end
        mc.mcCntlEnable(inst, state);
end
-- Cycle Start
if (sig == mc.ISIG_INPUT13) and (state == 1) then
    wx.wxMilliSleep(10)
    mc.mcCntlCycleStart(inst)
    mc.mcSignalSetState(hsig, 1); --sets Enable_3 to True
end
-- Cycle Stop
if (sig == mc.ISIG_INPUT11) and (state == 1) then
    wx.wxMilliSleep(10)
    mc.mcCntlCycleStop(inst)
    mc.mcSignalSetState(hsig, 1); --sets Opt Stop_1 to True
    hsig, rc = mc.mcSignalGetHandle(inst, mc.OSIG_ENABLE5);
    mc.mcSignalSetState(hsig, 0); --sets Enable_5 to False - Turn off
    spindlestate = 0
    mc.mcSpindleSetDirection(inst, spindlestate);
end
-- Feed Hold
if (sig == mc.ISIG_INPUT12) and (state == 1) then
    wx.wxMilliSleep(10)
    mc.mcCntlFeedHold(inst)
    mc.mcSignalSetState(hsig, 0); --sets Opt Stop_1 to True
end
-- Enable/Disable Spindle Button
 if (sig == mc.ISIG_INPUT15) and (state == 1)then --mc.ISIG_INPUT5--Used as an spindle button
       wx.wxMilliSleep(10)
        local reg = mc.mcSignalGetHandle(inst, mc.OSIG_ENABLE5)
        spindlestate = mc.mcSignalGetState(reg);
            if(spindlestate == 1)then
                spindlestate = 0
            mc.mcSignalSetState(hsig, 0); --sets Enable_5 to True - Turn off
            else
                spindlestate = 1
            mc.mcSignalSetState(hsig, 1); --sets Enable_5 to True - Turn on
            end
 end
local sigh = mc.mcSignalGetHandle(inst, mc.OSIG_SPINDLEON);
local sigState = mc.mcSignalGetState(sigh);
if (sigState == 1) then
else
end
-- MPG EStop
if (sig == mc.ISIG_INPUT10) and (state == 1) then
---wx.wxSleep(10)= 10 seconds
        local reg = mc.mcSignalGetHandle(inst, mc.OSIG_ENABLE0)
        estopstate = mc.mcSignalGetState(reg);
            if(estopstate == 0)then
                estopstate = 1
            else
                estopstate = 0
                mc.mcCntlEStop(inst, estopstate);
                    spindlestate = 0
                end
            end
end
-- E-STOP -- Input #20 to turn off Spindle Light
if (sig == mc.ISIG_INPUT20) then
end
Re: Spindle will not start with new versions of Mach4
« Reply #1 on: April 12, 2021, 11:51:10 PM »
hi
i can give you small advise how i made to debug ,when i have such problems(that my script not do what i want)
i enter some of this line
mc.mcCntlSetLastError(0,"line 55")---put the line number
in some lines where i think can be the problem
then you can see exactly until which line its did what you ask
Offline Mauri
  •  328 328
« Reply #2 on: April 13, 2021, 01:54:55 PM »
KatzYaakov,
I have used the same script for many years without issue, even before Mach V3804.
It is only the most recent Mach4/HiCON that now has this issue.
Mauri.
