Hello Guest it is November 02, 2026, 07:15:00 AM
Author Topic: Feed rate override - external controll  (Read 23302 times)
Offline Whacko
  •  239 239
  • Happy Days
Re: Feed rate override - external controll
« Reply #10 on: October 17, 2007, 03:23:53 PM »
Do you need to change the fro on the fly? If not you can type in the feedrate on the MDI page. Or just drag the slider. Disregard this if you need a pendant type of feed control. Then a modbus is the best way to go. Check the links page. HOMANN does a nifty modbus. I can do a simple feedrate only using a small pincount PIC MICRO. If you have access to programmer for PIC MiCRO's, let me know. If not, I can burn a chip, send it as a kit. That's the cheapest way.
Whacko
Nothing's impossible
« Reply #11 on: November 26, 2007, 10:20:31 AM »
this all about modbus and feed-/speed-override is very complex to me and i don't find pages where it's explained ...
can anyone gimme some help to use a modbus device and attached potentiometers for overrides ?
frank
