Hello Guest it is November 13, 2026, 09:36:09 AM
Author Topic: Rotate G code 180 ° for all 5 axes  (Read 15787 times)
« on: April 08, 2021, 02:39:11 AM »
Hey guys,
My company bought a 5-axis milling machine + Mach3 and want to use it to mill 3D tooth models (Aligner). We can create a gcode with fusion 360. We use a tray with 2 positions to fix the models. Position 1 is the normal one. Position 2 is rotated by 180°.
Now my boss would like to rotate the gcode (for position 1) by 180 ° so that the rotated part can be mill with the same code. We worked with G68 and G51, but it wasn`t successful, because g68 only turn X and Y-axis (not Z, B and C).
Does anyone have a solution for this?
Kind regards
Florin
