Hello Guest it is October 25, 2026, 03:15:38 AM
Author Topic: Mach4 Lathe Tool Probing (Help)  (Read 14954 times)
Re: Mach4 Lathe Tool Probing (Help)
« Reply #10 on: February 11, 2022, 02:31:56 PM »
OK, well here is the main script which is attached to a button - see what you make of it.  As I said, this is written in visual Basic so I don't know how easy it might be to change it to Lua.  But if you can see roughly what it's doing and how it might convert, then I could provide more bits and pieces.  But I think there could be a major difference in approach as you seem to want to use an existing probe, so I'd not sure the concept works quite the same way.
Enjoy!
« Reply #11 on: February 11, 2022, 04:14:36 PM »
Hi John,
Gerhard
