Hello Guest it is October 24, 2026, 09:27:21 PM
Author Topic: Mach 3 no communication with CNC machine  (Read 13468 times)
« on: March 19, 2021, 12:23:32 PM »
Hi All
     I have the following problem can anyone Help?
 My old computer was working ok with Windows XP but after a crash it is now U.S.
My new computer has Mach 3 installed but it will not drive the cnc controller. I
had an engineer fit a Parrallel card to run the cnc but it will not work. Is it due
to the 64 bit opperating system on the new machine? If that is so will the machine
work if i fit a parralell/usb converter lead?
As you have probably guessed I am a bit confused with this problem. Any help in
pointing me in the right direction would be appreciated?
Best Regards
Roy
Offline TPS
  •  2,627 2,627
Re: Mach 3 no communication with CNC machine
« Reply #1 on: March 19, 2021, 12:28:23 PM »
parallel port will only run with Win7 32Bit or older.
all newer require a external Motion Controller, not just simple usb to parallel Adapter.
« Reply #2 on: March 20, 2021, 12:15:38 PM »
Hi thanks for the answer. Can you advise what Model Motion Controller I should fit?
My current computer is a Windows 10 Home M/c  Version 20 M2. Can I use other
software on this machine or does Mach 3 need to be run on a dedicated computer?
Regards
Roy
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 20, 2021, 12:46:47 PM »
it depends on how much Money you whant to spend.
a 1:1 replace would be an UC100 (original no chinese chunk)
other's are (list is not complete and has no ranking)
-smoothstepper
-UC300
-UC400
-hicon
-CSLab
don't think about all this chinese controller's they are cheep but that is the only benefit.
« Reply #4 on: March 22, 2021, 01:31:38 PM »
 Many Thanks for your reply.
I will go for the UC100 as it has also been recomended by others.
Again many thanks your help is much appreciated.
Best Regards
Roy
