Hello Guest it is November 13, 2026, 11:29:17 AM
Author Topic: Z axis is lifting higher and higher after each cut  (Read 37049 times)
Offline TPS
  •  2,627 2,627
Re: Z axis is lifting higher and higher after each cut
« Reply #10 on: March 19, 2021, 05:38:34 AM »
can you pls post the script you are using? in original there is no msgbox instruction.
« Reply #11 on: March 19, 2021, 07:22:59 AM »
Oh yes, i deleted the msgbox.
The script looks now exactly like yours but unfortunately nothing happend.
It just moves to z 10 and to X&Y coordinates and then it stopped and nothing more happened (no probing).
But Z DRO was set to -3.4 mm, what is a success for me!
So now we have the case that Z was set to -3.4 but no probing.
Before with G31, the probing was fine but z was not set to -3.4.
Thanks!
Offline TPS
  •  2,627 2,627
« Reply #12 on: March 19, 2021, 07:38:47 AM »
Code: [Select]
Sub Main()
Code "G31 Z-150 F300.0"
While IsMoving()
WEnd
Sleep(200)
SetOEMDro(802, -3.4)
Sleep(200)
Code "G00 Z3.0000"
While IsMoving()
Wend
End Sub
--open Operator -> VB Script Editor
--copy and paste the code into Editor window
--with the >|| button you can run the script line by line (single step) and see what is happening
« Reply #13 on: March 24, 2021, 05:16:12 AM »
Don´t ask me what was wrong before but now it works!  ;D
I also tried M31 in a complete program and it works, too!
Many thanks for that!
Then the next question comes up.
Which post processor i can use for the m31 code?
I am using sheetCAM and i don´t want change all the progams manually.
Is there a post processor which i can use or change for the m31?
Thank you!
