Hello Guest it is November 24, 2026, 03:10:01 PM
Author Topic: autotoolzero  (Read 67468 times)
Offline PCH
  •  80 80
Re: autotoolzero
« Reply #20 on: February 28, 2021, 12:33:11 PM »
nope....its like its ignoring every line of code until it gets to this one:  Code "G1 Z1. F50"    ' put the Z retract height you want here, must be greater than the touch plate thickness
Offline TPS
  •  2,627 2,627
Re: autotoolzero
« Reply #21 on: March 01, 2021, 12:52:26 AM »
- open Main Menue -> Operator -> VB Script Editor
- copy/paste into the Editor
- use  >|| button to excecute code line by line
- see what code is doing
as sayed code was working here
Offline PCH
  •  80 80
Re: autotoolzero
« Reply #22 on: March 01, 2021, 01:21:19 PM »
Is this what I put in the macro and where?
Offline TPS
  •  2,627 2,627
Re: autotoolzero
« Reply #23 on: March 02, 2021, 01:23:12 AM »
1. open Main Menue -> Operator -> VB Script Editor
2. copy/paste the complete code into the Editor
3. use  >|| button to excecute code line by line
4. see what code is doing
Offline PCH
  •  80 80
autotoolzero
« Reply #24 on: March 02, 2021, 04:43:15 PM »
Ok...I have discovered the my macro will run if I do connect my wires to the breakout board.   But as soon as I connect them the after starting the auto zero script the z axis stops and then retracts to said height of 1 inch that is in the macro.
So befuttled.  Been at this for 2 days.  Must be a wiring issue I think.  Just about ready to get a new breakout board...maybe its a grounding issue.  Very frustrating..Need Help!!!
Offline TPS
  •  2,627 2,627
Re: autotoolzero
« Reply #25 on: March 04, 2021, 01:59:05 AM »
there are a few possibilities for the failue:
-wiring
-electric noise on your wiring
-defective BOB
Offline PCH
  •  80 80
Re: autotoolzero
« Reply #26 on: March 04, 2021, 05:59:45 AM »
Yep....ordered new breakout board and power supply.  Will do some rewiring.  Hope this works.  Thank you
