Hello Guest it is November 04, 2026, 06:27:21 PM
Author Topic: Following error  (Read 16758 times)
Following error
« on: February 22, 2021, 08:12:21 PM »
Hi all
I was able to work on my flame/plasma table some this weekend, and I ran into a problem.
I do not know if this is a HiCON problem, or a Mach 4 problem.
When I use either the mpg hand pendant, or write a few lines of Goode using the MDI command, everything moves correctly.   I can get all three axis moving at the same time with zero issues.
When I use sheetcam to generate Gcode, and I run this code. When I get to the line that detects the top of the part with a g31, I start getting following error
“ Error:  following error limit exceeded on Motor 0.  Servo disarmed.
Do you have any ideas?
Steve
Offline TPS
  •  2,627 2,627
Re: Following error
« Reply #1 on: February 23, 2021, 01:33:25 AM »
have a look here:
https://www.machsupport.com/forum/index.php?topic=44331.0
sounds like the same Problem.
